snoopynutz's avatar
snoopynutz
WN3000RPv3 -wireless connection dropping out
Wireless internet connection constantly dropping out since firmware update on September 16th 2019
  • plemans's avatar
    Sep 17, 2019
    If your landlords given you access to the router (aka you know the admin login) you can reboot it over the wireless connection as well as make wireless channel changes. I would recommend doing a wireless channel scan using either a free program for a computer or a free app. this will let you pick the best channel. I do recommend channel 1-6-11.
