snoopynutz
Sep 16, 2019Aspirant
WN3000RPv3 -wireless connection dropping out
Wireless internet connection constantly dropping out since firmware update on September 16th 2019
- Sep 17, 2019
If your landlords given you access to the router (aka you know the admin login) you can reboot it over the wireless connection as well as make wireless channel changes. I would recommend doing a wireless channel scan using either a free program for a computer or a free app. this will let you pick the best channel. I do recommend channel 1-6-11.
snoopynutz
Sep 17, 2019Aspirant
Woops,yes info would help...
1.Router: Netgear R6300v2 > Firmware: V1.0.3.6_1.0.63CH
2.I updated the extenders firmware to V1.0.2.78
3.I updated the extender wirelessly, did a factory reset and set it back up.
4.Connection page showing 144mbps
5.There are a lot of wireless networks around,however I have not had a chance to attempt to change the wireless channel because I live in a garage apartment and the main router is right downstairs in my landlords house and she is disabled so I have to have access in order to reboot router.I will try this ASAP however...Thank you so much for your help and patience.
Sep 17, 2019Guru - Experienced User
