ericjs54
Dec 01, 2021Follower
WN3000RPv3 Can I wirelessly connect this extender to a Google Mesh System
The Google Mesh access points don't have an ethernet connection. I would like to connect the Netgear extender wirelessly to the mesh system so I can run an ethernet cable from the extender to a music...
olympos1625
Dec 09, 2021NETGEAR Employee Retired
Hi ericjs54,
Welcome to NETGEAR Community!
Thank you for reaching out. We are sorry for not being able to get back to you immediately. You may use the Netgear extender to connect to your existing Google Mesh system. A similar setup process should be applied. You may check the links below:
https://kb.netgear.com/23517/How-do-I-set-up-my-NETGEAR-WiFi-range-extender
https://support.google.com/googlenest/answer/7139494?hl=en
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
