Gab92
Mar 21, 2019Aspirant
WN3000RPV3 cant connect on my windows laptop
Hello, i've been try to connect the wifi extender to my laptop unfortuanally everytime i try it says "unable to connect" , so i tryed with my mac and it worked . I Really need this to work on my ...
tlynch833
Jun 02, 2019Aspirant
Gab92
Did you resolve your problem? I have the very same situation and would like to know what you did
thanks to you
- Christian_RJun 07, 2019NETGEAR Employee Retired
Hello tlynch833 - If other devices are able to connect to the extender except your windows laptop, you may need to update your WiFi adapter driver on your windows laptop.
~Christian
- tlynch833Jun 07, 2019Aspirant
Hi Christian,
Thanks for your comments. My driver is from Realtek. According to their website I have their latest driver. Should I be looking for another driver vendor?
- Christian_RJun 10, 2019NETGEAR Employee Retired
Hi tlynch833 - May you check and see if your laptop is able to connect to the main network and access the internet.
~Christian
