Gab92
Mar 21, 2019Aspirant
WN3000RPV3 cant connect on my windows laptop
Hello, i've been try to connect the wifi extender to my laptop unfortuanally everytime i try it says "unable to connect" , so i tryed with my mac and it worked . I Really need this to work on my ...
tlynch833
Jun 02, 2019Aspirant
Gab92
Did you resolve your problem? I have the very same situation and would like to know what you did
thanks to you
Christian_R
Jun 07, 2019NETGEAR Employee Retired
Hello tlynch833 - If other devices are able to connect to the extender except your windows laptop, you may need to update your WiFi adapter driver on your windows laptop.
~Christian
- tlynch833Jun 07, 2019Aspirant
Hi Christian,
Thanks for your comments. My driver is from Realtek. According to their website I have their latest driver. Should I be looking for another driver vendor?
- Christian_RJun 10, 2019NETGEAR Employee Retired
Hi tlynch833 - May you check and see if your laptop is able to connect to the main network and access the internet.
~Christian- tlynch833Jun 11, 2019Aspirant
Hi Christian,
My Windows 10 / Chrome laptop and Windows 10 / Chrome desktop fail to connect to the network extender. My wifes Apple iPaD connects just fine. My laptop uses the latest Intel drivers on an Intel network adapter. The desktop uses the latest Realtek drivers on Realtek network adapter.
