Jluc
May 03, 2020Initiate
WN3000RPv3 can't upgrade firmware : failed to upgrade
Hello All, I put back to work an old WIFI EXTender WN3000RPv3 today. It works like a breeze (well not very fast compared to my ORBI...) but when I want to update the firmware (my very first m...
- May 04, 2020
version 1.0.2.52 fixed a firmware upgrade bug.
try installing that version first.
also, make sure you're extracting the firmware. Many just "open" the file but dont' fully extract it.
May 04, 2020Guru - Experienced User
- JlucMay 04, 2020Initiate
Many thanks !
I upgraded to 1.0.2.52 then to 1.0.2.80. Perfect.
Best regards,
Jluc.
