PD22
Mar 26, 2022Aspirant
WN3000RPv3 Firm Ware update
I was intending to update the firmware on my WN3000RPv3 extender which is presently V1.0.2.70 to the latest which is apparently V1.0.2.100 but from the Netgear genie Firmware Update list I clicked on...
PD22
Apr 06, 2022Aspirant
I am using the extender in extender mode. What I meant by correct address was mywifiext. This thread won't let me add .net because it won't let me save it if it includes an internet address. I indicated previously that the IP address assigned to the extender by my gateway is 10.0.0.38. Is that what you are asking for in your last paragraph?
michaelkenward
Apr 06, 2022Guru - Experienced User
Strange. It worked here.
You could always use a wired connection to the WN3000RPv3 and see if you can update the firmware in that way.
What happens when you try that in a different browser?
A useful network tool is the desktop genie for your operating system.
genie | Product | Support | NETGEAR
At the end of the day, though, we are talking about an ancient device that is beyond the reach of some of the usual tools,
- PD22Apr 06, 2022Aspirant
At this point I am going to admit defeat in trying to connect to and update the extender. It works so I will continue to use it with its current firmware version until it no longer functions. Thanks for your suggestions and time spent. I appreciate it very much.
