TerryJColes
Oct 15, 2019Luminary
WN3000RPv3 Loses Internet after Around One Week
I have now owned this Extender for over four years with no issues until now. For the first four years, this was installed in a room in the house with an Ethernet cable to make the connection to m...
TerryJColes
Oct 23, 2019Luminary
This device still loses it's connection after being unused for a period of time.
TBH, I've not tried downgrading the firmware because each time I make a change I have to see if it makes a difference. Selecting a different channel didn't help and I cannot move the device because there is only one power socket in the garage that I can plug it in to.
In the end, I'll probably just live with it and either wait for the next update or buy another device. After all, I only charge the car infrequently.
One option I've thought of is to move it back inside the house and connect it to the Router via Ethernet - I have a powerline adaptor that I rarely use. If the car and charger can still see the signal and it stops losing the connection, then I'll be happy.
Oct 23, 2019Guru - Experienced User
Or you can use that powerline device and install the wn3000rpv3 as an access point.
https://kb.netgear.com/25715/How-do-I-install-the-WN3000RPv3-as-an-access-point
