fluminus
Sep 05, 2012Guide
WN300rp cascaded?
I have 2 wn3000RP and I'm trying to configure a dgnd3700 v2. The first repeats the router's signal and the second signal repeater. I tried several times with dhcp configuration with static IP but from...
fluminus
Sep 05, 2012Guide
but how do I make it work? I can not in any way. I've tried using dhcp with static ip but on the second repeater when you connect a client does not receive IP address and blocks all network
