fluminus
Sep 05, 2012Guide
WN300rp cascaded?
I have 2 wn3000RP and I'm trying to configure a dgnd3700 v2. The first repeats the router's signal and the second signal repeater. I tried several times with dhcp configuration with static IP but from...
juanandresm
Feb 26, 2013Tutor
fluminus wrote: I have 2 wn3000RP and I'm trying to configure a dgnd3700 v2. The first repeats the router's signal and the second signal repeater. I tried several times with dhcp configuration with static IP but from the second repeater can not go on the Internet and the network slows down when they are connected to the second
Help me
Hey, I got a similar issue. I have a Router Cisco and two wn3000RP. I took one and configuretd to work sending the same ssid and it works fine. But when i connect and configure the second wn3000RP as a cascade from the first one, trying to connect any computer it doesnt get ip adress and doesnt transmit internet access. I tried a lot of diferents ways of connection and nothing did work. I think tha this devices does not support cascade configuration.
