tich51
Sep 26, 2012Follower
WN300RP Password problem
I hope somebody can help. I have plugged in the extender, it has connected via WPS to my router and when I go onto my iPad or laptop I can see the _ext wirelss connection. When I select the extender t...
NeoGeo
Oct 03, 2012Aspirant
wps isnt a big deal.
its better and easier to configurate manualy.
on the main router use WPA2 (AES) only.
asign all wifi devices via DHCP within a range of (xxx.xxx.xxx.001) up to (xxx.xxx.xxx.254).
after this was done reboot your router.
put in the wn3000rp and connect to it via wifi without extra software directly in windows/linux/osx.
open your browser and type www.mywifiext.net.
follow the steps and click on "use the router security settings - WPA2 (AES) with the same key.
after the setup has finished you will loose the connection to the wn3000rp ... reconnect with the WPA2 key > done.
btw. as next you can disable the device number of the wn3000rp cause of security risks. (www.mywifiext.net)
