tich51
Sep 26, 2012Follower
WN300RP Password problem
I hope somebody can help. I have plugged in the extender, it has connected via WPS to my router and when I go onto my iPad or laptop I can see the _ext wirelss connection. When I select the extender t...
mschnittman
Jun 29, 2013Aspirant
Force the unit to perform a hard-reset. This will ensure that the WN3000RP password will revert to the default (password). Enter the default WN3000RP IP address in your browser using a cable for connection. That should get you in.
