tich51
Sep 26, 2012Follower
WN300RP Password problem
I hope somebody can help. I have plugged in the extender, it has connected via WPS to my router and when I go onto my iPad or laptop I can see the _ext wirelss connection. When I select the extender t...
mschnittman
Jun 30, 2013Aspirant
It sounds like 1 of 2 things are going on:
1) verify that your ethernet cable is working properly between your PC and the WN3000RP. Are you using a cross cable by mistake?
2) are you positive that there isn't anything wrong with the WN3000RP? Has it worked properly in the past?
The directions I sent you should get you access to the admin settings of the router. There is something that's not quite right.
