tich51
Sep 26, 2012Follower
WN300RP Password problem
I hope somebody can help. I have plugged in the extender, it has connected via WPS to my router and when I go onto my iPad or laptop I can see the _ext wirelss connection. When I select the extender t...
hanham
Jul 02, 2013Aspirant
@Loffeking
Sorry but I understand why you have problems, because these people are giving you wrong advices.
If you reset your netgear to factory settings, plug it in power and then connect to it via WiFi with a wireless device like a Phone or tablet.
Then, when you are in the open wifi connection with the netgear, you go to the browser on that device and there you type www.mywifiext.net
Then you will start the install procedure.
There you can connect to your router and do all the settings.
Hans
Hans
