N_o_r_b_e_r_t's avatar
Sep 14, 2018
WN3100RPv2 does not start after firmware upgrade
Hello everyone,
I hope I will find a solution here. I have upgraded my WN3100RPv2 to latest firmware release WN3100RPv2-V1.0.0.60. Unfortunately I discovert aftermath that I have to upload the file manually instead of using directly from net... Any way all installation goes well till the router starts to reboot. Since I have the power light blinking green. I have tried
- power off/on several times
- reset factory
- 30/30/30 reset option found in this community
but nothing works. I have my laptop (Win10) directly connected to the router by ethernet cable and this router is not visible in wireless or thru cable.
So I cannot userthe tftp option as well.
Router was working just fine before upgrade and I was just willing to apply latest security patch. Now half of my house is stuck.
Does some can help?
Thanks
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi N_o_r_b_e_r_t,
    Welcome to the community!
    I have sent you a message. Please check your inbox.
    Dexter
    Community Team
