venkats
Feb 03, 2021Aspirant
WN3500RP - How to disable AP isolation configuration
Hi, I have used WN35000RP to extend my Guest Wifi network. I could connect internet and surf with devices. But when I try to use Chromecast and cast the video, I am unable to connect. As the...
Feb 04, 2021Guru - Experienced User
If you connect the WN3500rp to the standard network and not the guest network, does it work?
