vizakenjack
Jan 15, 2015Aspirant
WN604 - can't access router settings
I can't access routerlogin.net interface on WN604 through wi-fi. I have a mac pc. I guess I'd connect my pc via ethernet cable, but I'd need an adapter for that... Besides, I really prefer wi-fi... ...
Babylon5
Jan 15, 2015NETGEAR Employee Retired
Your DGND3700 is your network’s DHCP server, so in the WN604 at the IP Settings page select the ‘DHCP Client’ option. The WN604 will then be allocated an IP address from the DGND3700. When this is done I suggest that you log in to the DGND3700 and use the Address Reservation option to reserve the IP address allocated to the WN604, that way it should always receive the same IP address. You would then access the WN604 settings at that IP address e.g. http://192.168.0.13
