splatt1
Jan 30, 2012Novice
WN604 - can't access to set up
I can't access my brand new WN604 to even start to update it and set it up. I see that it's default address is 192.168.0.100 but I have it plugged in to a number of computers network jacks and it ...
algieuk
Feb 02, 2012Novice
splatt wrote: I can't access my brand new WN604 to even start to update it and set it up.
I see that it's default address is 192.168.0.100 but I have it plugged in to a number of computers network jacks and it always just says "Problem loading page" when i search that address in mozilla. The appropriate network jack light lights up on the WN604 and it even registers on my windows network centre as an "Unidentified Network - Local Only".
Why can't i find this thing to set it up... This is the first time out of the box, and I have even hit the Factory Reset.. still nothing.
Please help..
Thanks Matt
Just a thought, and something probably only older people would remember, but you are using a crossover cable if you are connecting direct to a computer aren't you? Otherwise you need to connect to a router or hub.
