tedster
Feb 16, 2011Aspirant
Wn604-100pes
Hi I bought the AP mentioned above to implement Radius as we already have 6 other Netgears that does not support radius , the WN604 seemed like a good idea. On the specs on the site , box & user ma...
Ardy
Tedster Did you get a response yet?
I just bought one of these WN604 access points too, purely because it promised RADIUS compatibility, i am getting the same problem as you even after the firmware update.
I will contact netgear too, in the hope it something something easy to resolve
good luck
good luck
