tedster
Feb 16, 2011Aspirant
Wn604-100pes
Hi I bought the AP mentioned above to implement Radius as we already have 6 other Netgears that does not support radius , the WN604 seemed like a good idea. On the specs on the site , box & user ma...
tedster
Feb 17, 2011Aspirant
Hmmm...nothing helpfull...yet..
Dear Etienne,
Thank you for choosing NETGEAR. My name is Mandeep and I will be your support engineer. I appreciate the opportunity to assist you.
Based on the complexity of this case, it may be appropriate for me to seek additional resources. I recommend escalating your case to the next level for further review and response. I strongly believe that you will be contacted at the earliest.
This message is for your information only. There is no additional action needed from you at this time. The next level support engineer will update the case and you will be notified.
Again, thanks for choosing NETGEAR and we appreciate your continued patience. We will get back with you shortly.
A system generated e-mail will be sent to your e-mail address to inform you that we have responded to your inquiry. Please DO NOT REPLY to the e-mail sent to your e-mail address. Instead, if you want to reply to the message above and have additional query, please click "no" when the system ask you "Was your problem resolved with the information provided by the NETGEAR representative above?" When you select YES, your case will be closed and a separate e-mail containing a survey link will be sent to you to measure your customer support experience.
Thanks again for choosing NETGEAR. Have a great day!
Sincerely,
Mandeep Kaur
Technical Support
NETGEAR, Inc.
***Please be aware that your case will auto-close after 7 days of inactivity***
Did you know that NETGEAR provides support for your home networking devices and PCs? One-stop solution! No need to call multiple vendors* for support. If you would like to learn more about the NETGEAR GearHead services please click on this link
Dear Etienne,
Sincerely,
Mandeep Kaur
Technical Support
NETGEAR, Inc.
