brianberns
Jun 18, 2013Aspirant
WN604 cannot connect to router
I have purchased a WN604 access point to provide wireless networking in my home. I have a cable modem (Cisco DPC3825) from my ISP (Mediacom) that works fine as a router/gateware for wired connections....
fordem
Jun 18, 2013Mentor
You either have a problem with the cable, the ports or speed/duplex negotiation - try a known good cable, try a different port on the router, one that you can test as working with another device, if those don't work try connecting the access point to a switch or PC to verify if the port on the access point itself is functional - this last might require a cross over cable.
Remember - what we're looking for is link lights - without a link there can be no communication.
