jlittle78
Dec 04, 2011Aspirant
WN802 and latest 3.1.1 firmware
I was having an issue with me WN802-200 dropping random connections during the day. I'd have to disconnect the wireless adapter from the AP and then reconnect it.
I decided to update the firmware to the latest 3.1.1
After i did that reset the AP to factory default like the instructions said to but now i am unable to setup the security features anymore. I just get an error on the Security screen saying "fatal error: required field for select missing".
I have downloaded the firmware 3 times and tried upgrading 3 times.
Are there any known issues with this latest firmware?
Thanks
Thanks
- jmizoguchiVirtuosoMakes sure you are flashing the firmare via wireless
Make sure you hard reset the unit afer the flashing the firmare - jlittle78Aspirantthx for reply.
they just released firmware 3.1.9 and i was able to successfully update my WN802 unit with that.
I upgraded the firmware via Cat5 cable, then did a hard reset as suggested and it worked fine.
Thanks Again - jmizoguchiVirtuoso
jmizoguchi wrote: Makes sure you are flashing the firmare via wireless
Ops.. Make sure you are NOT.... via wireless
My phone missed some typing - jmizoguchiVirtuoso
jlittle78 wrote: thx for reply.
Thanks Again
Sounds great. Enjoy
