AFH
Jul 12, 2012Follower
WN802T - limited access/no internet
Hi I really hope someone can advise. I've scoured these forums and Googled myself ragged trying to work out the problem but have had no success. Here is my basic setup: - ADSL into a Billion Bi...
Jack_
Jul 15, 2012Aspirant
- Seems all settings and configurations are OK.
- Don't use same SSID for router and AP.
- Configure AP channel to #11 or #9. Have you checked that no other WLANs are active in your area?
- Disable security completely on AP and try to connect.
- If that works then try all security modes available until you run into a problem.
- Then you should know what specific problem you were facing all the time....
