gyc_uk
Sep 30, 2007Aspirant
WN802T is it dead???
Hiya guys, Is my access point dead? I have a WN802T, which i have had for about 6 months. I came home today to do some work in the office. The Network connection light is out, the wireless light...
jeb
Jan 21, 2008Aspirant
We had one at work that went down in August/September (bought May/June). Didn't bother with support for it, simply replaced it with another one (different brand though)...
Surely a lot of companies/people that does exactly the same?
Nevermind, I brought it home som time ago, picked it apart tonight and removed the internal mini-pci. It started! :) Reflashed it with the latest firmware. So, the problem seems to be with the hardware of the mini-pci? I'll try to check the pins later when time is given. As soon as you plug the mini-pci in, the lan light goes out, seems allmost like a short circuit?
Anyone else who has opened theirs and allready measured the pins??
BR Jeb
BTW: It does work nicely in my bookshelf! If you fill it with lead it will even hold "Foundations of Computer Science" (another brick) in place! :D
BR Jeb
