gyc_uk
Sep 30, 2007Aspirant
WN802T is it dead???
Hiya guys, Is my access point dead? I have a WN802T, which i have had for about 6 months. I came home today to do some work in the office. The Network connection light is out, the wireless light...
keith721
Oct 24, 2008Novice
I recently purchased a factory refurbished WNR854T from geeks.com for a ridiculously low price. The first thing I did was put away the 12VDC power adapter that came with it. It wouldn't start with a 6VDC power adapter, but runs perfectly using a 9VDC adapter. If I had a 7.5VDC adapter, I'd try that next, because I suspect this unit might operate using that voltage. Why they over-supply the board with three (or more) excess volts of power is beyond me. But I'd think it might have contributed to the high failure rate. If all you want is a replacement radio card, buy one of these refurb units and get a perfect replacement. The worst part is unsoldering :eek: the mini-PCI retaining clips on either side of the board. But definitely find a lower voltage power adapter to supply your units. It can't hurt (unless your wireless coverage becomes too weak) and it may very well help extend the life of your unit. Hope this helps someone. :)
