LaneyG
Apr 22, 2011Novice
WN802T v2 and iPAD connection issues.
So I bought my new iPAD2 but I can't get the internet to work when at home through my WN802T access point. Any help would be appreciated to save me buying a new router / access point. Both my home ...
LaneyG
Apr 23, 2011Novice
Thanks both for replying.
I can't get into my WN802 admin page. NO default IPs work and I can't find out from the software you recommended Jack (it says it isn't compatible with my system :confused:).
When I run the cmd command, it tells me DHCP is enabled on my wireless, but under Windows IP configuration section it says " IP routing enabled: No" Could that be the problem? I can't find where on my computer to change it.
I've just tr4ied changing my iPAD to a static setting using all the information I gleaned from running the ipconfig command, but no joy.
