LaneyG
Apr 22, 2011Novice
WN802T v2 and iPAD connection issues.
So I bought my new iPAD2 but I can't get the internet to work when at home through my WN802T access point. Any help would be appreciated to save me buying a new router / access point. Both my home ...
Jack_
Apr 23, 2011Aspirant
Follow my instructions to find IP location of WN802T using netstumbler or similar utility.
Then follow June's suggestion to disable N on WN802T. Could be that iPAD does not support N but only G. :confused:
Or you need to enable N on the iPAD if all else fails.:cool:
