LaneyG
Apr 22, 2011Novice
WN802T v2 and iPAD connection issues.
So I bought my new iPAD2 but I can't get the internet to work when at home through my WN802T access point. Any help would be appreciated to save me buying a new router / access point. Both my home ...
jmizoguchi
Apr 23, 2011Virtuoso
Issue will make sure to know what IP tha WN is.
If you originally dis not setup, WN is still on default IP so if existing network is not insane LAN subnet then making static ip same as ipconfig will not reach WN
Ex.existing network is 192.168.1.x
WN802t is default ip 192.168.0.230
You need to set PC on right subnet
If you dont know then reset the WN and hook up PC directly to WN and use static ip in PC and gain access.
