illusjon
Jan 13, 2010Aspirant
WN802Tv2 firmware upgrade failure (Bricked)
Hi. When I got this AP, the first thing I did was upgrade the firmware, and after letting it upgrade for almost a hour, I thought the process was finished although the GUI didn't show any sign of i...
Scottyboy
Jan 14, 2010Aspirant
It seems like you must have been successful in upgrading the firmware in the unit, then, at some level, it can't communicate.
Is there a new GUI version download as well?
I wonder if it could be a Windows driver update that occurred somewhere in the mix.
Do you have a different computer that you can use to isolate if it is on the WN802T side or the PC side to split the problem apart?
