larrycor
Apr 02, 2019Follower
WNA3100 Wifi dongle - looking for driver
I am looking for driver software for my Netgear Wireless N-300 USB adapter WNA3100.
When I download the file which is currently available on the Netgear website (52mb) it turns out to be software f...
Apr 02, 2019Guru - Experienced User
When I download the file which is currently available on the Netgear website (52mb) it turns out to be software for Express Burn DVD burning.
Has the Netgear website been hacked; or is it a deliberate ploy by Netgear to not make available this software?
I just downloaded it to check. Mine downloaded fine. The file needed to be unzipped once downloaded and within the folder it contained:
1. release notes
2. A stand alone driver setup
3. A drive and genie setup
I even was able to install the driver (and then uninstall as I don't have that device)
here's the link to the wna3100 that I downloaded.
http://www.downloads.netgear.com/files/GDC/WNA3100/WNA3100-SW-V2.2.0.4.zip
- plemansApr 02, 2019Guru - Experienced User
oh and once the main folder is unzipped, you need to unzip the specific stand alone or driver + genie folder.
