danmunchie
Aug 07, 2011Aspirant
WNCE2001 + PS3 Issue
Hi all, Hoping someone can assist with my connection issue. My setup is: [WD Elements 2TB HDD]---[Synology USB Station 2]---[Billion BiPAC 7800n]--(Wireless G+N)--[Netgear WNCE2001]---[Sony Pla...
danmunchie
Aug 28, 2011Aspirant
Thanks for that. I tried going back to DHCP IP with no change.
I tried the wall adapter for power, and this DID solve the problem... but... it also highlishted what was the original problem.
It seems that the WNCE and PS3 starting up simultaneously causes the issue.
If I turn power on at the wall (WNCE turns on) and turn on the PS3 immediately, I have the same problem. If I wait for the WNCE to connect to the wireless BEFORE turning on the PS3, problem solved.
Strange, but at least it's a solution. Odd that this problem isn't seen by more people since it appears to be a WNCE/PS3 conflict unrelated to my router (I assume).
Cheers,
--Dan
Cheers,
--Dan
