intense98rt's avatar
intense98rt
wnce2001 adapter issues
I bought a wnce2001 adapter to use with my printer. I hooked it up to my win7 laptop to set up the wifi on it. Now with the adapter not connected to my laptop, I have issues with the netgear smart wizard configuration assistant trying to manage the internal broadcom adapter.
How do I uninstall or disable the netgear from my laptop?
  • Setup only need to use browser to access the WNCE initially and do not install anything unless you end up install something yourself then uninstall the application
  • The WNCE isn't connected to my computer anymore. I have a built in wireless. The setup maybe once every couple weeks will open up in my browser and I have to go through the setup if I want to connect to the network. Any way to stop it from coming up?
