monaco87
Mar 07, 2011Aspirant
WNCE2001 and static IP address
I have just bought one of these to use on an xbox but I need the xbox to have a static IP address. So I decided to test it on a Windows 7 PC to and to set it up. Firstly, is it correct to say that ...
jmizoguchi
Mar 07, 2011Virtuoso
reconfiguring for two hours and no matter what I do, the static address setting on the WNCE results in a DHCP address on the PC.
setting up static IP on WNCE2001 will NOT change device behind the WNCE2001.
WNCE2001 is transparent unit once connected to existing wireless. PC and/or device must have static IP if you want pc and/or device needs to have static ip
