monaco87
Mar 07, 2011Aspirant
WNCE2001 and static IP address
I have just bought one of these to use on an xbox but I need the xbox to have a static IP address. So I decided to test it on a Windows 7 PC to and to set it up. Firstly, is it correct to say that ...
jmizoguchi
Mar 07, 2011Virtuoso
WNCE2001 is setup for DHCP client so should get IP from existing network
setup will also tell you to use "domain name " to access which will automatically get you to the WNCE2001 interface. wether you use static IP or DHCP Client makes no difference for some and some prefer but that least of problem since it still acts transparent and you can hook up switch behind and connect more than one devices.
