monaco87
Mar 07, 2011Aspirant
WNCE2001 and static IP address
I have just bought one of these to use on an xbox but I need the xbox to have a static IP address. So I decided to test it on a Windows 7 PC to and to set it up. Firstly, is it correct to say that ...
NetworkGenie
Mar 11, 2011Aspirant
The WNCE2001 is a 'Wireless Client'. It's actually so easy to set up. If your router has WPS then press that button on both the router and the WNCE2001. If your router does not have WPS, that's okay just connect it to your computer and launch a web browser and the GUI will launch. If for some reason it doesnt' just go to www.mywifi.ext. Once paired with your network you're all set and can take it from device to device for easy use. I use this on my XBOX360 and have had no issues with online gaming.
