monaco87
Mar 07, 2011Aspirant
WNCE2001 and static IP address
I have just bought one of these to use on an xbox but I need the xbox to have a static IP address. So I decided to test it on a Windows 7 PC to and to set it up. Firstly, is it correct to say that ...
Dado1964
Nov 01, 2013Aspirant
Hi To all
I have a similar problem with WNCE2001
I am using static ip adresses because the lan port is connected to a lan printer.
I setup correctly the device for connect to a cisco wi-fi. and it work good
The address of the device is:
IP: 10.133.3.196 S/N: 255.255.255.0 : GW: 10.133.3.1
The ip of the printer is
IP: 10.133.3.195 S/N: 255.255.255.0 : GW: 10.133.3.1
At first connection is ok, but after some time i loose the connection to the printer.
If i chenge the ip adress of the printer return to work but for some time and then down again.
Could someone help me?
Thanks
Thanks
