ccd1006
Jul 28, 2016Aspirant
WNCE2001 bricked after updating firmware v1.0.0.15_1.0.1
I updated my firware to v1.0.0.15_1.0.1 and now the router is bricked. I followed instruction in the readme and updated with cable (vice wireless). I tried to reset and it did not flash the int...
ccd1006
Sorry, wrong model.
Travel router PR2000 vice WNCE2001
- DarrenMAug 01, 2016Sr. NETGEAR Moderator
Hello ccd1006
If you believe the device is bricked you can check to see if its still under warranty and contact Netgear support.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
- ccd1006Aug 01, 2016Aspirant
I called netgear and itss out of warranty and they wanted $s to help fix. So, looks like I am going to get another one. Too bad as netgear no longer makes and I did like its functions / versatility. Thanks.....
