ccd1006
Jul 28, 2016Aspirant
WNCE2001 bricked after updating firmware v1.0.0.15_1.0.1
I updated my firware to v1.0.0.15_1.0.1 and now the router is bricked. I followed instruction in the readme and updated with cable (vice wireless). I tried to reset and it did not flash the int...
ccd1006
Sorry, wrong model.
Travel router PR2000 vice WNCE2001
DarrenM
Aug 01, 2016Sr. NETGEAR Moderator
Hello ccd1006
If you believe the device is bricked you can check to see if its still under warranty and contact Netgear support.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
- ccd1006Aug 01, 2016Aspirant
I called netgear and itss out of warranty and they wanted $s to help fix. So, looks like I am going to get another one. Too bad as netgear no longer makes and I did like its functions / versatility. Thanks.....
