gazurtoids
Nov 15, 2013Aspirant
WNCE2001 browser?
Condsidering getting one of these to connect to a blu ray player... My question is can you browse the web fully when connected ie through a browser or does it only run apps like netflix etc?
corvairbob
May 02, 2014Tutor
so i tried that link and it fails i get problem loading page. any other ideas. i plugged in the adapter to my computer using the usb plug and the Ethernet cable to the modem and i don't get the welcome screen or anything else.
so lets start from the beginning i just got this and plugged it into the player bdp-s185 i configured the player for the internet. but it will not connect.
you said to plug it into the computer and it would conned with a welcome greeting and then let me configure it? nothing happens.
i have a steady power light and the lan light is on and no wifi light when i first plug it in the power is dim then gets bright then the klan lights up and flickers some then goes steady. i can't tell the color.
so where should i see this statements on the computer screen as i don't have it connected yet to a tv for this part. thanks
