gazurtoids
Nov 15, 2013Aspirant
WNCE2001 browser?
Condsidering getting one of these to connect to a blu ray player... My question is can you browse the web fully when connected ie through a browser or does it only run apps like netflix etc?
schumaku
May 02, 2014Guru - Experienced User
Of course not - you need to connect the Ethernet and the USB to your computer - the USB is just to provide power, the WNCE2001 can be configured over the Ethernet only. Temporary disable any other wireless connection from your computer to the WLAN.
corvairbob wrote: i plugged in the adapter to my computer using the usb plug and the Ethernet cable to the modem and i don't get the welcome screen or anything else.
Please consult the WNCE2001 Installation Guide FMI.
