dpmaki
May 30, 2013Follower
WNCE2001 Can't Connect via WPS
I have a Netgear Router with WPS as well as the WNCE2001. The directions for the WNCE state to wait until you have solid green power led and then push the WPS button. You will get a led that blinks ...
markfirkins
Jul 03, 2013Aspirant
I cant help you with your problem as I have the same difficulty and would be pleased if you have had success and can help me.
Also I cant find how to post an original message on this forum. How did you manage to do that?
Regards
Mark Firkins
Regards
Mark Firkins
