hb64's avatar
hb64
Follower
Mar 12, 2011
WNCE2001 Feature Request - http
I'm sure I'm not the only person who has encountered this. The device 'behind' the WNCE2001 is accessed using http. But instead I usually get the WNCE2001 http management page when I try to access the device behind.
Request capability for WNCE2001 http interface to be assigned to listen on a port other than 80.
Thanks...
  • put your request by sending a support at my.netgear.com and use open technical submission
    Thanks...
    mine is working ok so far......i'm just curious what is your device model no. you have connected with WNCE2001?? is it a special device or something else?
  • Make sure you have the latest firmware. Can you confirm if you're running v1.0.0.21NA ?
    I know this is an old thread, but I'm having the same problem. In fact I can't access the device behind the WNCE2001 at all (ssh, http, ping, anything). My router shows that both the WNCE2001 and the device behind it are getting IP addresses. I'm running firmware V1.0.0.26. Does anyone have any suggestions?
