flaaash
Jun 13, 2012Novice
WNCE2001 loses connection after a few hours
I am able to connect to the router and get on the internet, but after 16-18 hours, I lose connection. At which point I need to power down and power up the adapter by removing and plugging back the pow...
jmizoguchi
Feb 03, 2013Virtuoso
I would say 10M/32ft, is quite a distance. Unless you have line a sight or not obstacle it may be difficult.
WNCExxx would has same effect as most other USB WIFI adapter. You should test other wifi devices and see what is the signal is like.
