flaaash
Jun 13, 2012Novice
WNCE2001 loses connection after a few hours
I am able to connect to the router and get on the internet, but after 16-18 hours, I lose connection. At which point I need to power down and power up the adapter by removing and plugging back the pow...
CDOGG5
Feb 19, 2013Aspirant
mjburns wrote: flaaash: Did you ever resolve your problem? I have the same issue, even when the WNCE2001 is sitting a foot away from my Cisco RV110W and the WNCE2001 is set to have a static IP address. The unit clearly has issues maintaining the WLAN connection, despite it's default Fragmentation Length of 2346, CTS/RTS Threshold of 2346, and Long Preamble are at the most tolerant end of those settings. It will often drop it within minutes, then re-establish within a few more minutes (often with a yellow WLAN LED instead of green), then drop, etc. At some point, it just drops it forever.
I think my has just dropped forever. I had to keep resetting it and it worked for awhile until finally i reset it and nothing happened. The wps light has not come back on and i think it is gone forever. Do i need to buy a new wireless adapter?
