ztevie
Aug 27, 2011Guide
WNCE2001 questions...
Hi! I have a samsung tv. I'd like to use a wireless connection for internet tv, but not Samsung's own dongle. I understand WNCE2001 will work by connecting Ethernet from tv to it and the connect wire...
ztevie
Aug 28, 2011Guide
Thanks for your help!
I was thinking since range is not an issue that using 802.11n on 5 ghz would give me better performance, might even be able to stream HD material from the pc.
But ok, the WNCE could be the best option. The other one you mentioned seem to be discontinued here in Sweden anyway.
I'll look around a bit more before I decide.
Any suggestions for a nice n-router with usb hdd possibility?
