EricRFMA
Oct 20, 2010Aspirant
WNCE2001 setup problems
Greetings, sources of all knowledge...! Here's the scenario: iMac G4 (700Mhz), read: Old. Mac OS X 10.4.11 Wireless networks (2 different ones were involved in this story) Netgear WNCE2001 ...
jmizoguchi
Oct 20, 2010Virtuoso
Encryption was enabled and was 128bit WPA2 (I believe... doing this by memory at the moment).
bad memory.. there isn't 128bit for WPA... it is 128bit WEP and hackable one unless you are using WPA2
setup static IP on mac using "DHCP with manual address" also try public DNS on mac side as well
