EricRFMA
Oct 20, 2010Aspirant
WNCE2001 setup problems
Greetings, sources of all knowledge...! Here's the scenario: iMac G4 (700Mhz), read: Old. Mac OS X 10.4.11 Wireless networks (2 different ones were involved in this story) Netgear WNCE2001 ...
EricRFMA
Oct 21, 2010Aspirant
Thanks again for your replies!
Two followup questions, just to clarify...
When you say the "address is outside of the range of the router", do you mean the Verizon FIOS-supplied router?
Also, what should I choose as a static IP address? Will the WNCE2001 respond no matter what I pick? Is it dependent on the settings on the Verizon FIOS-supplied router (which I can examine and change if necessary?)
Thanks!
-Eric
Thanks!
-Eric
