EricRFMA
Oct 20, 2010Aspirant
WNCE2001 setup problems
Greetings, sources of all knowledge...! Here's the scenario: iMac G4 (700Mhz), read: Old. Mac OS X 10.4.11 Wireless networks (2 different ones were involved in this story) Netgear WNCE2001 ...
jmizoguchi
Oct 21, 2010Virtuoso
When you say the "address is outside of the range of the router", do you mean the Verizon FIOS-supplied router?
is there other device does DHCP? ask yourself. :)
Also, what should I choose as a static IP address? Will the WNCE2001 respond no matter what I pick? Is it dependent on the settings on the Verizon FIOS-supplied router (which I can examine and change if necessary?)
I did say out side of DHCP range. also long as you use outside of DHCP range then it will be based on your how you range the DHCP
