EricRFMA
Oct 20, 2010Aspirant
WNCE2001 setup problems
Greetings, sources of all knowledge...! Here's the scenario: iMac G4 (700Mhz), read: Old. Mac OS X 10.4.11 Wireless networks (2 different ones were involved in this story) Netgear WNCE2001 ...
decypher01
Oct 26, 2011Novice
Do a reset on your WNCE2001 connect the adapter again to your laptop (TURN OFF YOUR WIRELESS) if it is giving you 192.168.1.100 that's normal since the adapter provides that kind of IP, no need to set static on the LAN adapter just use Dynamic.
as soon as you connect to your main network thru the interface the WNCE2001 will provide a new IP range in line with your main router.
