jp0213x
Jun 28, 2014Aspirant
WNCE3001 blocking AV web interface over wireless
Hi all, I am using a WNCE3001 to connect to my Yamaha AV. Everything works fine until I try to access my AV web interface from any wireless device on my network. I am unable to connect via phone or...
jp0213x
Jul 02, 2014Aspirant
Problem solved by disabling WLAN partition.
WLAN Partition under Advanced Wireless settings. I had to disabled WLAN Partition prevents associated wireless clients from communicating with each other. This feature is on the Dlink DIR 655. Wireless Isolation I think it might be called.
